Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2009 Honda Civic limp mode problems
Old Apr 4, 2021 | 10:51 AM
crw1287's Avatar
Default 2009 Honda Civic limp mode problems
Working on a 2009 Honda Civic 1.8 5 speed came to me with a bad engine got another 1.8 from another 2009 Honda Civic automatic car. Swap went great fires right up went to drive it made it about 1/4 mile and check engine light starts flashing won’t rev up turned around and made it back to the house checked the codes doesn’t have any. Unhooked the battery for a minute or so fired it back up revs up fine till about 3-4000 rpm then check engine light starts flashing no codes again. Looked over everything seems tight and hooked up. Both grounds I took off on driver side and passenger side I cleaned and hooked back up not sure what I’m missing. My google search said something about the alternator being loose can ruin the ecu it’s tight. Not sure if I need to change something on the engine like a sensor since it came from an automatic and mines a 5 speed. Any help is appreciated!
Jeremiah Ward
Feb 8, 2021 03:17 PM
JIMH
Dec 3, 2012 01:49 PM
kaleem
Honda Civic (2001 - 2005)
Nov 23, 2009 08:59 AM
streetchemistry2000si
Dec 15, 2008 09:42 AM
Speed_69
Apr 14, 2006 04:48 PM
