Making sure I have everything before I start ripping it apart...Any advice
Old Mar 28, 2021 | 11:07 AM
Stopsign32v's Avatar
Loved
Icon4 Making sure I have everything before I start ripping it apart...Any advice
So step one is going to be the timing belt replacement and head studs...Here is my list of parts:
  • OEM head gasket
  • ARP head studs
  • Gates timing belt
  • OEM water pump
  • OEM oil pump
  • OEM timing belt tensioner
  • OEM timing belt tensioner spring
  • OEM valve cover gasket
Next I plan to do a tune up and get the car ready for boost
  • OEM cap
  • OEM rotor
  • NGK BKR7E spark plugs
  • NGK RC-HE82 spark plug wires
Can anyone see something I'm missing so far? I don't want to start into it and realize I missed something obvious.
Old Mar 28, 2021 | 11:10 AM
Txdragon's Avatar
Default Re: Making sure I have everything before I start ripping it apart...Any advice
  • OEM head gasket
  • ARP head studs
  • Gates timing belt
  • OEM water pump
  • OEM oil pump
  • OEM cap
  • OEM rotor
Don't forget fluids!
Old Mar 28, 2021 | 11:12 AM
Loved
Yea and I'm also contemplating on doing an ATI street balancer. I'm 50/50 on doing that now or later.
Old Mar 28, 2021 | 11:20 AM
Txdragon's Avatar
I'd totally say do it now if ya can.
Old Mar 28, 2021 | 11:59 AM
Loved
So the car isn't tuned obviously. Should I get more than just 4 spark plugs?
Old Mar 28, 2021 | 12:10 PM
Txdragon's Avatar
you can but, not much reason to do that unless you're gonna put a couple thousand miles on them before tuning.
Old Mar 28, 2021 | 01:41 PM
highschooler's Avatar
Sometimes people change the cam seals also when doing the timing belt. If you're changing the oil pump, won't you need an oil pan gasket also? I'm not sure, but I would think so. Also, if you plan to turbocharge, are you sure you need an OEM head gasket, or would you want to go with another one now such as JE Pro seal or Skunk2 multi-layer?...
Old Mar 29, 2021 | 07:49 AM
LightningTeg's Avatar
Community Builder
Yes
Wouldnt worry about the dampener personally. ATI makes a nice piece though.
Old Mar 29, 2021 | 07:50 AM
Community Builder
OEM always IMO
Old Mar 29, 2021 | 08:15 AM
Loved
Sorry forgot to mention that. I have a Myhondapro or whatever it is called gasket and stud kit. The oil pan will be a Moroso being bunged and welded by none other than Greg at Autoworks for the miniram manifold placement.
And what cam seals? I'm not removing the cam gears.
Old Mar 29, 2021 | 08:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
With the head off, it's a good time to replace the water pipe o-rings while you have easy access. You'll need a tube of HondaBond or Permatex Ultra-Grey for resealing various places. Other things to consider replacing while you're "there":
  • oil jet o-ring
  • oil pickup gasket (it's usually crispy)
  • plug wires if they are older
  • Anything else rubber that is accessible - gaskets, hoses, etc.
Old Mar 29, 2021 | 04:30 PM
The cam seal is behind the cam gear. If it's not leaking, then it's ok. It's for preventative maintenance.
Old Mar 29, 2021 | 06:15 PM
Loved
Ah ok...No I'm not going to do that. I don't plan to keep this head very long. Will be going Vtec as soon as I can source a head.
jdmfreak1992
Honda Civic (2001 - 2005)
Jul 21, 2010 01:44 PM
hybrid1990crx
Sep 19, 2006 04:52 PM
99blackdc2
Jul 13, 2006 08:30 PM
schumi
Jun 10, 2005 08:56 AM
arren123
Dec 11, 2003 09:46 PM
