Honda 1991 crx
Old Mar 27, 2021 | 10:36 PM
Dan120's Avatar
Default Honda 1991 crx
Died on me thought it was running out of gas got gas it died makes a pop sound back fire's when trying to start anyone know what's wrong with it? Timing ? Ignition?
Old Mar 29, 2021 | 06:45 AM
TacoCat's Avatar
5 Year Member
Default Re: Honda 1991 crx
There could be a hundred things wrong and without any more information no one is going to be able to give you an answer. Here are some things I would do to narrow down the possibilities:
1. Check that the fuel pump is running
2. Check that you are getting spark at the spark plugs
There are lots of common problems with a CRX. Here are some:
  • Rust in the tank causes the fuel pump to die
  • Main relay solder joints
  • Ignition (key) contact failure
  • Distributer coil / igniter
  • Timing belt jumped a tooth / broke
  • Ground issues
All of these are well documented in this forum and others. Do some testing, narrow down the problem and try to solve it.
Old Apr 4, 2021 | 02:07 PM
TeeTee580's Avatar
Sounds like the screw in your dizzy is loose.
Unscrew the cap of your dizzy and check if the rotor in it rotates freely.
If it does, the screw holding it to the shaft is loose.
Common issue...
The rotor spins at random, sparks a spark plug at will, making poping sounds in the exhaust
thecorey
Honda CR-V & Element
10
Dec 26, 2022 10:22 AM
OHrexer
16
Jul 18, 2013 02:29 PM
Chewy Built !
10
Jun 16, 2006 09:49 PM
T_Rex
Dec 6, 2002 10:41 AM
Driven
Jun 24, 2002 06:14 PM
