alternate oil filter for integra
Old Nov 16, 2002 | 04:57 PM
au-gsr's Avatar
Default alternate oil filter for integra
guys wondering if you know if there is a larger oil filter that will fit the integra thread pattern? and if so, how much larger is it then stock(reason i'm asking becasue a larger filter would dictate a lil more oil).
Old Nov 16, 2002 | 05:10 PM
Ferrell's Avatar
Default Re: alternate oil filter for integra (au-gsr)
whats wrong with oem?
Old Nov 16, 2002 | 05:21 PM
Tweakmeister's Avatar
there are slightly larger filters out there but if you want more oil go with something like an oil cooling system. That will give you more oil + cooling.
Old Nov 16, 2002 | 05:27 PM
frogsr's Avatar
Default Re: alternate oil filter for integra (Tweakmeister)
sounds like a good option. or you could go with a larger oil pan, like one from moroso, for example.
Old Nov 16, 2002 | 05:37 PM
Dan GSR's Avatar
Default Re: alternate oil filter for integra (frogsr)
Mobil M105 fits perfect
you may need to take out a bracket that holds the intake manifold from the bottom....useless anyway
Old Nov 16, 2002 | 06:06 PM
vtecdc2's Avatar
Default Re: alternate oil filter for integra (Dan GSR)
i heard the RSX filter fits.. can some one confirm? i think i read it here on HT
Old Nov 16, 2002 | 06:13 PM
au-gsr's Avatar
Default Re: alternate oil filter for integra (VTECDC2)
oh god no! ! !
don't ruin the integra forum with a rsx comment!!!
j/k
but if it works and you use aftermarket/mobil one filters let me know what number it is, . No reason to spend 20 bux on an oem rsx filter when you can get a better one for 10.00.
Old Nov 16, 2002 | 06:28 PM
skunkintegra's Avatar
has anyone experienced the HAMP oil filters..(green colored filter)
supposedly spoon sports...see them on ebay all the time!
just wondering if anyone has used them, or know if they are better then oem?
thanks
Old Nov 16, 2002 | 08:37 PM
piatl7il77's Avatar
Default Re: alternate oil filter for integra (skunkintegra)
I have heard that the HAMP oil filters are a waste of money. Just stick with OEM.
Old Nov 17, 2002 | 02:45 AM
hitop's Avatar
Default Re: alternate oil filter for integra (piatl7il77)
for oil filter, stick w/ oem. I'm saving up for custom cup-holders
Old Nov 17, 2002 | 04:45 AM
FORCED FED TEG's Avatar
New User
used this one my car for a couple years now.
Old Nov 17, 2002 | 05:55 AM
lewylou's Avatar
get a HAMP oil filter....they come is small and large sizes
Old Nov 17, 2002 | 08:31 AM
GSRaCeRbOI's Avatar
Old Nov 17, 2002 | 07:20 PM
Default Re: alternate oil filter for integra (GSRaCeRbOI)
for you go ahead with the Mobil 1 or cooling system or both
With regards to Hamp filters... I took apart an oem filter and was not impressed. I have yet to take apart a Mobil 1 filter (give me a couple of weeks) but am curious to take a peak. I am currently running a small version of the Hamp on my vehicle because I wanted the higher pressure... I'll chop it up too once the time comes.
holmesnmanny
Dec 10, 2009 03:14 AM
happynoodleboy
Feb 20, 2008 06:34 PM
Sohc Driver
32
Jul 15, 2003 02:46 PM
Tweakmeister
Feb 23, 2003 01:54 PM
ITR Demon
May 16, 2002 07:40 PM
