1997 Accord LX Automatic: engine won't turn over
Old Mar 25, 2021 | 03:44 PM
robertmeredith's Avatar
Default 1997 Accord LX Automatic: engine won't turn over
Happened all of a sudden....the motor will not crank. Battery fine, cables are fine (I removed the ground cable and dressed the ends), with key in on position all dash lights, radio etc seem to work fine. Moving key to start position, no clicking, no typical solenoid sounds, nothing. Also, with the headlights on, moving key to start position, there's no discernible dimming in the headlights. Anybody have any thoughts?
thanks!
Rob
Old Mar 25, 2021 | 06:52 PM
99stockcivic's Avatar
Default Re: 1997 Accord LX Automatic: engine won't turn over
First thought is the ECU, if it won't even turn over it has to be drastic!
Old Mar 25, 2021 | 11:33 PM
Jeremy64's Avatar
thanks! You can try to jump the solenoid see if it cranks. Also a 50amp fuse under the hood. If manual the clutch interlock. If auto the gear position switch or not in park.
Rob
Old Mar 26, 2021 | 04:10 AM
Thanks for the input! It's an automatic. The battery feeds an 80 amp fuse in the under-the-hood fuse box, and it appears intact. I'll try to jump the solenoid and see if that might identify the problem.
Old Mar 26, 2021 | 04:16 AM
hondaslave1342's Avatar
Whack the starter with a hammer or something
Corton93
Oct 23, 2018 02:50 PM
5_Lug_B
Oct 2, 2007 07:10 PM
morgn905
Jan 18, 2007 05:58 PM
alainarcand
Dec 18, 2005 05:17 PM
