Engine Code 8 & 9 Still Persisting after dizzy change
Old Mar 25, 2021 | 09:53 AM
ZimbuVTi's Avatar
5 Year Member
Icon5 Engine Code 8 & 9 Still Persisting after dizzy change
Hello,
As the title suggests my EG is currently suffering from code 8 & 9 (sometimes its 8 or 9). It was running fine for a bit with these on but at a point it would start and randomly turn off, then it would crank and not start up.
Changed the dizzy with the new one today and still nothing has changed. Starts up for a bit then eventually it turns off again. Timing on the dizzy should be fine so no clue what to do next.
Any help would be appreciated.
Old Mar 25, 2021 | 08:02 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Engine Code 8 & 9 Still Persisting after dizzy change
If you didn't set the ignition timing after swapping the dizzy, then you can't assume it's fine.
I would also trace and continuity check all wires from the dizzy to the ECU. If resistance is more than 10 or 20 ohms it would be suspect. I think it should be under 10 ohms for the distance if I remember correctly.
Oh and ground G101 is also a likely area for challenge.
Lastly, many of the dizzy wires are shielded wires, if they've been cut and spliced at any point that too could pose a problem.
Old Mar 25, 2021 | 09:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Check your thermostat ground. Check continuity for both pairs of wires for the sensor pairs you have trouble with. Swap in a known good ECU and see if the codes go away.
Old Apr 11, 2021 | 08:11 AM
ZimbuVTi's Avatar
5 Year Member
Bumping this thread to update.
Ended up taking the car to a local mechanic and the guy discovered that their was some shady wiring running from the dizzy to the ECU which ended up burning around three tracks on the ECU itself hence why the car sometimes won't start and throws codes etc.
Bought a new P08 ecu and has been running fine for the last 3 days. Did bring up code 1 for oxygen sensor last night, here's hoping its not too much of an issue.
monster d
Jun 12, 2013 10:20 PM
padoda94
Apr 9, 2013 01:33 PM
93egtypeR
24
Aug 5, 2010 01:04 PM
drinks2k
May 10, 2007 10:15 PM
JonGP4
Jul 26, 2003 06:13 AM
