Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
New axle seal leaking
Old Mar 24, 2021 | 09:10 PM
joenobodyyet's Avatar
10 Year Member
Default New axle seal leaking
I have a 2008 Civic LX automatic sedan with 107,000 miles. A few months ago I installed new CV axles and brand new seals where the axle shaft enters the transmission. The driver's side axle seal (National brand 710314) seems to be leaking because reddish fluid is leaking where the seal is onto the shiny metal where the axle enters the transmission. It also looks like the fluid is splashing in that area (I assume from the rotation of the axle shaft). I removed the axle and removed the new seal, then I put it back in. I made it as flush as I could with the outer part of the transmission. But it's still leaking. Should the seal be pushed in more? Should the seal be pulled out a hair? I just don't want to keep taking this apart and putting it back together and continuing to have a transmission fluid leak. I did not grease the seal but I did put transmission fluid on the outer and inner part edges of the axle seal. Should I use a grease? What grease? I have sil-glyde. Any tips on this seal leak would be appreciated! Thanks!
Emeraldbomber
10
Feb 22, 2019 07:38 AM
GI8U2racing
Jun 3, 2009 03:57 PM
driveslow
19
Mar 5, 2009 07:03 PM
ED9man
Apr 7, 2007 12:09 PM
See Are X
Oct 21, 2003 09:23 PM
