Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
OBD Connector No Power
Old Mar 23, 2021 | 10:52 AM
DrewusMaximus's Avatar
Default OBD Connector No Power
Hi all, 08 LX-P 5 SPD unknown mileage
I am new to the forum and just purchased an 08 LX 5 speed. The OBD connector isn't working. I plug in my reader, turn the key to the On position, and the reader doesn't power up. I've read there's a 15a fuse on the circuit the connector is on, but the coil pack relay is also on that circuit. If the fuse is bad, it would affect the coil packs and I would have an issue with the coil packs. Is that true? Is there somewhere I can check and test? Is there another fuse to look at?
Thanks in advance!
Old Mar 26, 2021 | 09:52 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: OBD Connector No Power
Link in my sig will help
Old Mar 26, 2021 | 02:37 PM
johnnybgood1's Avatar
Old Mar 26, 2021 | 02:57 PM
Thank you! I will look at it and see if any of them are stretched, but in case that isn't the problem, where is the fuse located? This is what I found, but not sure if that's the correct fuse. It mentions DLC, but does that fuse handle the OBD connector?
15 BACK UP 10A
Audio Unit, Audio-HVAC Sub Display Unit, DLC, Driver's Door Courtesy Light (4-door), Driver's MICU, Front Passenger's Door Courtesy Light (4- door), Fuse 5 in Passenger's Under-dash Fuse/Relay Box, Gauge Control Module, HandsFreeLink Control Unit (Navigation), Immobilizer-Keyless Control Unit, Microphone (Navigation), Navigation Display Unit (Navigation), Navigation Unit (Navigation), Passenger's MICU, Power Window Master Switch
Old Mar 27, 2021 | 03:29 PM
I was able to solve the problem. The 15a fuse was blown. Popped a new one in and voila! Back in business...
BSturgeon
May 30, 2020 03:34 PM
kalfirst
Honda CR-V & Element
Sep 2, 2019 07:25 PM
green eyed bandit
Nov 16, 2011 06:14 AM
vodkaTM
Dec 9, 2008 08:58 PM
SIC_jdm_da9
Audio / Security / Video
Apr 20, 2007 10:50 AM
