Making your own engine harness?
Old Mar 17, 2021 | 06:41 AM
Hondanoobie1's Avatar
Default Making your own engine harness?
Im new to the hondas i owned a 94 accord with vtec. My car got totaled and i want to keep the rebuilt engine. So im swapping its drivetrain into a 95 metro that was given to me. So i need help with making a stand alone harness i've even pulled the dash and removed all the dash harness since the engine computer connectors where wrapped in with it. I was wondering in there is a pin out of the harness or if someone else has already done it?
Old Mar 17, 2021 | 11:20 AM
Aradin's Avatar
Premium Member
Default Re: Making your own engine harness?
For the ECU wiring there are pinouts available if you Google search. For other wiring, the Honda service manual will be your best friend as it has very detailed wiring schematics of all the systems.
Old Mar 17, 2021 | 12:05 PM
GhostAccord's Avatar
First step is to separate and depin the chassis wiring from the ECU wiring on both the under dash and engine bay looms and connectors. Then take all the ECU/Engine wiring and tape it all back up to suit your current build.
that's all I did.....
by GhostAccord, on Flickr
Happy wiring!
As mentioned above there are detailed Honda wiring schematics available for the 94-97 Accords.
Old Mar 17, 2021 | 12:10 PM
99stockcivic's Avatar
Hey very impressive. Way to be resourceful. Are you going to bring over the axles as well? I don't think the GEO axles (being a toyota / GM mix) will fit right. Then you will have to size the axles since they might be too wide.
Old Mar 17, 2021 | 12:14 PM
I'm not really familiar with the Geo Metro, but I'm thinking the wiring harness will be the easier part of this swap.
Unless you can swap the front suspension components as well.......
Old Mar 17, 2021 | 12:26 PM
Agreed, that's why I thought it was interesting to attempt this. The size of the vehicle, a hybrid of Japanese and American into one car, I had a friend with one and it was always interesting to get parts, since sometimes it matched to a Suzuki part and sometimes to a Chevy part, with both metric and standard bolts on the car. He'll need custom engine mounts, trimmed axles from the Honda as the Geo was only a 60hp car or so this will be a big boost to that car.
Old Mar 17, 2021 | 12:42 PM
Be cool to see once it's done.
Old Mar 18, 2021 | 07:31 AM
yes im pulling the axle out of the honda and the metro. And once engine is placed to get measurements im goin to take both sets and have the cv axles made so they will fit in.
Old Mar 18, 2021 | 04:54 PM
I suspect you will need a some work to make the steering work as well. Maybe pull the steering column to get the right splines to fit.
So are you thinking to move the rear over as well, or just live with two different size wheels, the front being Honda and the back being Geo.
And, what's your plan to get the front brakes to work? Bring over the hubs and rotors and the brake booster?
Post pictures as you do the work, I'd like to see the motor mounts mocked up myself, as those are in quite different locations on the two cars.
Old Mar 19, 2021 | 07:44 AM
im keeping the booster and steering from the geo. Im just going to make the mounts for motor and trans. As for pictures how do i post them in this tread or start a new post?
Old Mar 19, 2021 | 08:28 AM
You should see a attachment button in your reply message area. Or if you have a cloud link you could dump those there as well.
Old Apr 3, 2021 | 02:46 PM
blg5035's Avatar
10 Year Member
Looks like a fun project! Sub'd
Adeeb1395
K Series
May 7, 2019 11:29 AM
Adeeb1395
Jul 31, 2017 06:18 PM
komet 163
Sep 27, 2016 04:50 PM
chrysanderson
Mar 24, 2011 05:42 PM
