Honda accord 2008 won't start
hello everyone
I have a 2008 honda accord 2.4L with 60.000 miles won't start. the battery and starter are good because I can hear it working. I have a scanner I checked, nothing wrong. I checked the gas is going to the engine. anybody has an idea please? thanks
Have you checked to see if the spark plugs are firing? Also, is your fuel pump working? You stated that you have a scanner, I am assuming you mean a OBDII scanner. What codes are you seeing?
I didn't check to sparkplug and the fuel pump is working good. it shows 0 code! I also just released at the oil level was low. I add 1 litter and a half. I hop it's not the timing chain..
Robert Reynolds
Oct 11, 2019 01:01 PM
hannan44@gmail.
May 18, 2017 01:28 AM
VeroNole08
Nov 13, 2013 06:55 PM
