D16y7 Automatic D16y8 intake mani swap
Old Mar 10, 2021 | 06:44 AM
99civiclxauto's Avatar
Icon5 D16y7 Automatic D16y8 intake mani swap
Hi all, new to the forums and i have a question, what would i need to get a d16y8 intake mani to work on an automatic d16y7? i havent been able to really find anywhere else talking about the specifics of the swap and whatnot.
Any help is appreciated, thanks
Old Mar 10, 2021 | 10:48 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: D16y7 Automatic D16y8 intake mani swap
You will need an automatic Y8 manifold so that you can still use a 3-wire IACV, just like you have on the Y7 manifold. Your Y7 ECU will not operate a 2-wire IACV. Also, make sure you get the same version type intake manifold. If your engine is a '96-98, then get a '96-98 auto Y8 I/M... if your engine is a '99-00, then you need to find a '99-00 auto Y8 I/M.
Old Mar 10, 2021 | 10:52 AM
I do have a 99-00 so I would need that same version, but everything else should be fairly plug n play?
Old Mar 10, 2021 | 08:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I want to clarify my above post... I don't want to lead you down the wrong path. You will need a '96-98 EX (Y8) style automatic intake manifold regardless of what year Y7 you have. The '99-00 EX intake manifold has an additional vacuum port across the top edge that would create a huge vacuum leak on your cylinder head. The intake manifold selection is only critical for Y8 (EX) style cylinder heads, and the '96-98 and '99-00 model year break dictates which intake manifold you would use... NOT for the DX/LX "Y7" type cylinder heads.
As for everything else being "plug and play"... you will have some wire/plug moving, and maybe some needs to be lengthened... but it IS straight forward.
itinerant
Apr 30, 2011 06:57 AM
Wazup
Dec 13, 2004 06:22 AM
speedehatch
Dec 23, 2003 11:42 AM
fastcrxsi90
Dec 24, 2002 03:51 PM
fastcrxsi90
Dec 24, 2002 10:03 AM
