oil leak between head and block on front right corner near oil resturn passage?
Old Mar 8, 2021 | 04:49 PM
Farzan Dean's Avatar
Default oil leak between head and block on front right corner near oil resturn passage?
So I just finished a turbo d16 build and after the first startup I noticed some oil leak between head and block on the front right corner of the engine. I had both the block and head work done at the machine shop, and I also put in a .050" cometic MLS head gasket on it, And did the torque sequence all the way to 67ft lbs. And after a couple heat cycles, and retorqing the head head studs, it still leaks from that corner in the front right. It has a new dizzy oring, and new vtec gaskets. Also I notice a small leak near the back of the block and not sure where? Also I put a new valve cover gasket from autozone, and I dont see fresh oil anywhere on the head, and I only see oil around block.
Old Mar 11, 2021 | 01:11 PM
weekendboost's Avatar
Default Re: oil leak between head and block on front right corner near oil resturn passage?
Did you check top and side of vtec solenoid? Might be worth using an oil dye to figure out where it's coming from.
Old Mar 12, 2021 | 02:01 PM
cfoss's Avatar
Very likely vtec solenoid or distributor oring
Chay
saemoonyang
12
Jun 7, 2010 02:01 PM
bks84
Apr 18, 2009 04:04 PM
blinx9900
Dec 30, 2008 10:01 AM
null.
Dec 25, 2004 01:45 AM
ENeRg3Tic
Apr 30, 2004 06:43 AM
