Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Hi Guys. I have a fog light issue 2015 Accord
Old Mar 6, 2021 | 07:16 PM
Daniel Vitolo's Avatar
Default Hi Guys. I have a fog light issue 2015 Accord
Not sure if they ever worked. But just recently I installed LED bulbs in headlights. Looks great. Then I decided that I want to do the same to my fog lights. To my surprise, fog lights don’t come on. I went to check the #4 Fuse engine bay, and it was blown. I replaced it with the correct 15a and it blew again. Now I’m not sure if the light setting was on in the car when I replaced fuse, but pretty sure it didn’t matter. Anyway, wondering if there is a short? Also If so, does both sides have a wiring harness and is there a harness that connects those 2 harnesses together. Any help would be greatly appreciated. Thx.
Also, if a harness is shorting it, can I fix it, or do I have to replace it? Last question, Could it be the bulbs? Both are out. Would that short the fuse like that? Thx again all.
Old Mar 8, 2021 | 05:48 PM
Default Re: Hi Guys. I have a fog light issue 2015 Accord
Just wondering if there is a more active Honda tech forum then this?
Old Mar 12, 2021 | 02:35 AM
Trey Griffin's Avatar
Hey check right at the foglight where the pigtail plugs into the LED Bulb or HiD bulb and see is there a pinch in the wire also make sure the bulbs that you're using aren't defective I would suggest using HID if you're using them neither.
Old Mar 12, 2021 | 02:40 AM
Also make sure the bulbs aren't plugged backwards because I've found its possible and it could blow the fuse as well. Also test it before you put the bumper back up also be sure to turn the fog lights on the switch is the 2nd toggle on the light switch.
Old Mar 12, 2021 | 05:41 PM
Will do. Thx for responding. I never replaced fog light bulbs so I don’t know how they could be backwards but I will check for pinch in Wire. Thx again
CivicVtec23
Feb 12, 2013 03:12 PM
patrickvertigo
Lighting
Nov 16, 2009 12:06 AM
mister.wong
Jan 27, 2008 12:41 AM
PleaseHelp
Oct 8, 2004 05:31 AM
Blk_prl
Sep 2, 2003 11:34 AM
