2014 CRV - Interior Lights Not Working
Hello,
I've a 2014 Honda CRV. None of the interior lights are working - Map Lights, Ceiling Lights or the lights on the Sun Visor. The little blue light next to the Map Light is on.
The switch (next to the Map lights) is set to Door.
I checked/replaced the fuse under the hood - fuse # 28
I also replaced the Map light bulbs - but no luck.
Any assistance anyone can provide in helping identify the issue would be much appreciated.
Thank You!
Thank You!
Verify first whether it is a power (+) issue or a ground (-) issue.
Measure if there is power on the orange wires going to the map light, ceiling light, or vanity mirror lights. If there is power present on the orange wire, then check for continuity to ground on the respective component's black wire.
To measure voltage:
- Generally for most car components, unless your meter is auto-ranging, set the voltmeter to the 20 volts setting.
- With the voltmeter, touch the meter's red lead to the wire/component/etc. you want to measure/check the voltage (which would be the orange wires in your case); and the meter's black lead to body ground (chassis bare metal; such as a ground bolt or bracket, etc.).
- Set to either the "ohms" or the setting it will beep when you hold the two leads together.
- When you want to test a wire or component for continuity, touch one end of the meter's lead to one side of the wire/component; and the meter's other lead to the other end of the wire/component.
- If your meter beeps, it means you have continuity.
- If it is on ohms scale, you will have continuity when it reads close to 0 ohms.
- If it doesn't beep , shows OL (open line) or a 1 (infinity ohms); it means you don't have continuity.
wtemale
Nov 18, 2017 05:08 PM
Occidentalis
Honda CR-V & Element
May 5, 2017 09:13 AM
ftrms
Dec 2, 2009 11:40 AM
