So was swapping out my old stereo and everything was good. Put everything back yesterday and the ac switch that controls the intensity of air was good. Went to fix something on my stereo today put everything back together again and now this time no matter if I switch my air to off or any number it just continously blows. All the other switches work, the ac button works, the hot and cold air work....everything. ...any ideas? Thank you for your help.
Pull the dash back apart and pull the AC part partially out. See if it stops. Then start wiggling the wires around it, it's probably shorted in some manner by accident. I have had a similar item happen to me when swapping stereo. In my case I jammed all the stereo wires in a little bit the wrong way and it was pushing/pulling on the AC and switch panel. Just had to straighten it out, tape it up nicely, and then put it back in more gently, and it was fine again.
