Team Loyalty's B20VTEC and Nitrous? What's the best controller to use?
Old Feb 28, 2021 | 12:25 PM
Team Loyalty's Avatar
5 Year Member
Default Team Loyalty's B20VTEC and Nitrous? What's the best controller to use?
I have a semi build b20v with a dry nos kit install with relay and switch on steering but I had a ? I wanted to get my car tune but I want to have both step up all motor and with nos can it be done with nos on a switch not on the ecu. I was thinking if I get it tune with nos would it hard to drive when I don’t want to race with the nos cause of the fuel and air being higher cause of the nos I want to spray sometime not all the time so should I get the nos connected to my s300
Old Feb 28, 2021 | 08:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Team Loyalty's B20VTEC and Nitrous? What's the best controller to use?
Yes, it should absolutely be connected to your s300. This requires an "activation" switch, and once activated, the computer will engage the N2O when all specified conditions are met. The advantage of this is that the engine will perform it's very best NA and will perform safely on the spray when called upon. The days of relying on the button are long behind us.
Old Mar 1, 2021 | 09:50 AM
Full_Tilt's Avatar
https://www.hondata.com/help/smanage...ml?nitrous.htm
BIG T
Feb 26, 2008 12:45 PM
lsvtec225
Mar 18, 2007 05:28 AM
dubman410
Jan 4, 2005 02:59 PM
TurboT
Nov 9, 2003 04:50 PM
Defiantpeformance
Oct 14, 2003 11:26 PM
