New Honda guy here
Old Feb 27, 2021 | 05:37 AM
Nickh5817's Avatar
Default New Honda guy here
Hello members. Just picked up a beautiful 1994 ex coupe white with 154k for $1750. Wanted a daily driver since all my other vehicles don’t like running. Drive it for two weeks and then was doing slight touge and long story short I had to replace the rear trailing arm bushing on one side side after it totally ripped it out and it looked like I had bent an arm.
A friend of mine also has a civic and suggested that I do a disc brake swap so I’m currently in the process now with a integra rear trailing arm swap along with rear control arms and the 13 or 14mm sway bar that came with it, with poly bushings all around except for the compensator arm and camber arms. Probably will pick up some adjustables down the line. Also picked up tein street advances and am reusing the old top hats to install.
So far the civic has been easy towork on and I’m glad I picked it up. Can’t wait to see where it takes me.
Old Feb 27, 2021 | 07:33 AM
denverjdm's Avatar
Loved
Default Re: New Honda guy here
very clean coupe! i had a 95 ex back in 2010. first upgrade i did was rear disc/oem sway bar. much improved over stock.
teaks92hb
12
Nov 22, 2011 11:22 AM
Jimmy
32
Apr 4, 2011 09:26 PM
boosteddb1_808
Aug 29, 2010 03:07 PM
Do_Ster
Feb 20, 2004 01:25 AM
00 FBP ItR
May 15, 2003 05:02 AM
