Tps trouble
Tps has 12v supply! I just swapped a 97 h22 into my 2000 ej8 y8 obd2b. I cant figure out what is going on. I've deloomed the engine harness and cant find any exposed or pinched wires. I dont have the map and tps mixed up either. Please help!
so I found out that my ecu ground to the thermostat housing needed a good sanding. So once I did that I got a correct reading.
jfruauff
10
May 3, 2008 11:41 PM
