91 crx dx no crank or relay click
I have a 91 crx I bought for 600 bucks it’s been sitting without the engine in it for 3 years I bought the car put the engine back in it made sure everything was hooked up right all grounds and fuses was good I would get a click out of the starter relay here and there but starter was bad so I bought a new starter then o wouldn’t get no click out of starter relay. I took relay case apart and when you turn the key if you press the relay in with finger to make contact it will crank the engine so I bought a new relay think that the relay was bad put. New relay in it same thing no crank. I get dash lights but the hatch light is dim and I get no radio lights if I put a relay that is set up different and push clutch in I get all lights inside on radio. But it’s the wrong relay so it will not turn the car over but as I said if I take my finger and push on the metal part inside the relay so the it makes contact it will turn the engine over I desperately need help I been on this same problem for 3 weeks and had my buddy look at it that’s good on cars and we can’t figure it out. any help I been on many many many different forms but no one is have it the same problem as me I seen some kinda close to mine so I read and read and still nothing that is the same problem as I am having please help
markviiisvt4
Sep 17, 2006 11:48 AM
ghost_ryder35
Sep 7, 2005 05:53 PM
