'01 Accord 4 cylinder coolant leak on back of engine
Old Feb 22, 2021 | 08:55 AM
FAUSTJOSHUA's Avatar
Default '01 Accord 4 cylinder coolant leak on back of engine
Hey all, thanks in advance for any advice and or suggestions. I have a coolant leak on the drivers side back of the engine block. Thought it was a freeze cap until I got my phone back there to take a picture, it's a very small hole that sits above the freeze cap I believe. I've done a good bit of searching around, and am unable to identify what this is called to get a replacement cap/plug. Guys at the local auto parts store have no clue, gave me a freeze plug kit with a bunch of plugs to try, all of them too large.
Old Feb 22, 2021 | 11:08 AM
99stockcivic's Avatar
Default Re: '01 Accord 4 cylinder coolant leak on back of engine
Can you zoom out and take another picture to help with perspective of where it's located? I know the pipe that runs back there, but this looks a little different. Is it next to the knock sensor?
Old Feb 22, 2021 | 11:17 AM
Aradin's Avatar
Premium Member
That's the weep hole for your water pump. Your water pump is in the process of failing and needs replacement.
Old Feb 22, 2021 | 11:21 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Agreed.
Old Feb 22, 2021 | 11:23 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here is another thread with similar photos.
https://honda-tech.com/forums/honda-...ngine-3258238/
Old Feb 22, 2021 | 02:17 PM
I feel silly I didn't recognize that myself.
If you are in there, you might want to just do everything, water pump, timing belt, seals.
Aisin kit with water pump is the one I used the last time.
https://www.rockauto.com/en/catalog/...nent+kit,16088
acbettis
Apr 26, 2018 12:33 AM
Ken D.
Apr 22, 2018 11:08 AM
88fourdoor
Mar 4, 2011 03:59 PM
tjowers
Dec 14, 2009 01:01 PM
my97accord
Jan 31, 2005 05:20 AM
