Has any one built a d16a6/z6 mini me for boost
Old Feb 12, 2021 | 12:46 AM
purposebuilt's Avatar
Default Has any one built a d16a6/z6 mini me for boost
I know there should be alot.. hi I have a built a d16a/z6 head and am woundering what turbo your running and when it hit full boost. Dyno numbers.. here my build
d16a6 block
speedfactory no notch long rods
vitara pistons.75.5 bore (cr 9;1)
acl hi performance oil pump
king racing bearing
Auto zone water pump
Autozone timeing belt
D16Z6 HEAD
BC valve springs and steel retainers
Supertech valve seals
Stock refresh. (Lap valves, polish valves. Resurfes head(.(minimal)
Skunk 2 intake manifold and 70mm tb
Aem fuel rail, blox fuel pressure reg
stock fuel lines,, aem 320lph fuel pump
Bosch 1000cc ingeters
.now for turbo this where I need help.. if been looking at a go auto works cast manifold or a 1320 ram horn .and also have a problem finding the right turbo. If been looking at a gt3071 with .63a/r compressor and .5 turbine. Or a tx-50e-57. I know that would spool alot faster but capable of 23+psi and 400-450whp thanks in advance
also if any one has built a d16a6/z6 heaf i would love to ask you questions
Old Feb 14, 2021 | 06:11 AM
Marcos Barrios's Avatar
Default Re: Has any one built a d16a6/z6 mini me for boost
i didnt have a mini me swap
i had the d16a6 motor with a supercharger back in the day
pushing 6 pounds of boost
it almost made 200 hp 194 hp on the dyno
purposebuilt
Feb 16, 2021 04:35 PM
Ghunt521
Oct 13, 2012 11:18 AM
MilanoEj1
Sep 12, 2010 09:15 AM
Garcia505
Jul 16, 2010 12:03 AM
sony224422
May 4, 2007 02:33 PM
