D15B2 water pump pipe/hose question.
Old Feb 10, 2021 | 06:05 AM
niko2020's Avatar
Default D15B2 water pump pipe/hose question.
Can someone please give me pointers how to take the pipe that goes into the water pump off? I need it on the new block since the old one is toast. I have attached pictures. Thank you!
It’s the pipe on the bottle of the pic that goes into the water pump.
Old Feb 10, 2021 | 08:33 AM
ax77's Avatar
10 Year Member
Default Re: D15B2 water pump pipe/hose question.
just pull it off. You'll probably have to twist and pull. The o-ring is probably making it stick
Old Feb 10, 2021 | 08:41 AM
niko2020's Avatar
thanks for the reply. Thought about doing that without damaging it. The pipe is shaped concave around the o-ring preventing it to slide out easily. I’ll try to straighten the concave shape with pliers and give it a try tonight unless somebody else have a better idea.
Old Feb 10, 2021 | 12:23 PM
DaX's Avatar
DaX
Loved
Community Favorite
Do not straighten it out - you will make it leak. Just grab it from the back side with both hands and pull it out while wiggling it back and forth. Don't be afraid to man-handle it.
Old Feb 10, 2021 | 12:26 PM
niko2020's Avatar
Thank you. I’ll try that and update you guys.
Old Feb 11, 2021 | 06:00 AM
niko2020's Avatar
just like you guys said with a little bit of wiggling it came right out. The gasket is what created a tight fit. Thank you
Old Feb 11, 2021 | 06:29 AM
DaX's Avatar
DaX
Loved
Community Favorite
I like to put a very small amount of grease (I use polyurea, because that's what I've got) on the new o-rings when reassembling. It prevents the o-ring from sticking and rolling out of its groove when being reassembled, which will cause it to leak. It also makes the next removal just a little easier.
Old Feb 11, 2021 | 08:17 AM
niko2020's Avatar
I'll remember that. I'm sure I've got some laying around in the garage somewhere. Thank you
Jagan'92
Apr 2, 2019 07:01 AM
Edgar Cruz
Honda Civic (2001 - 2005)
Dec 18, 2015 06:18 PM
sasinorm01
Feb 15, 2011 06:08 PM
swt_666
Apr 8, 2007 02:23 PM
