Honda CR-V & Element 2WD & 4WD Element & CR-V
Variable Timing Solenoid now in two pieces
Old Feb 9, 2021 | 06:49 AM
Mike Waldron's Avatar
Default Variable Timing Solenoid now in two pieces
P0011 code. I tried to remove the control valve to clean it, and the solenoid came off and left the piston part in the motor. Has any one seen this? I tried to pull it out with plyers but no luck. is there a tool or trick to get the 2nd part out. It has 190,000 miles and has never been pulled out.
Old Feb 9, 2021 | 01:49 PM
Davey7847's Avatar
Default Re: Variable Timing Solenoid now in two pieces
Its usually 1 piece.
I have never seen one break apart like that. .
I would try to insert a screw in it and pull it out. That's a head scratcher for sure.
NeKe1point0
Feb 25, 2022 05:23 PM
Spitz
Oct 22, 2008 05:34 PM
lmike6453
Mar 18, 2008 11:14 AM
stRodda
Aug 7, 2004 06:04 PM
RTW DC2R
Dec 23, 2002 01:33 PM
