Honda PS Pump Pics
Old Feb 8, 2021 | 06:11 PM
hawks85's Avatar
Default Honda PS Pump Pics
Can any of you Honda Guru's tell if this is a actual Honda pump or is it a pump bought at Oreilly's, Autozone etc...I can't tell.
Old Feb 8, 2021 | 08:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Honda PS Pump Pics
Not a Honda pump... it is aftermarket.
Old Feb 8, 2021 | 08:48 PM
hawks85's Avatar
Thank you. How can you tell?
Old Feb 9, 2021 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The sticker is not OE.
Old Feb 11, 2021 | 02:01 PM
Hasport's Avatar
just because the sticker isnt OE doesnt mean the pump isnt. that pump appears to be OEM and probably what happened was it was rebuilt and then the sticker was put on
the pump isnt new or shiney like something right out of the box plus i dont know that anyone makes an actual aftermarket pump
Old Feb 12, 2021 | 02:07 PM
hawks85's Avatar
The thing is certain aftermarket parts look exactly like the real one, right down to the bolts etc...it's really hard to tell if it's a actual Honda pump rebuilt or not. I can't find a pic of a 99 civic pump so I can compare. Besides the sticker there has to be something on the actual pump that isn't on a aftermarket, a marking etc...
Old Feb 13, 2021 | 07:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I tend to agree with Hasport.
Aftermarket will not look exactly like OEM unless it's a china knock off. Aftermarket does not copy casting stamps etc. Also aftermarket with a new sticker like that WOULD be shiny and new unless it was an OEM rebuilt. Then it's just acid washed, rebuilt and sent with rebuilt cataloging sticker put on it.
Or the other likely possibility is it's a professional used part seller, they pull parts and put their inventory sticker on it then sell it.
Old Feb 13, 2021 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
In my experience, even a re-manufactured P/S pump from Honda will still have a sticker on the edge with the 3-digit type/chassis designation on it just like an original pump. This could be P06, P72, P13, etc. depending on the application. This sticker doesn't appear to exist on the pump pictured above.
So now we are getting into the minutia of what constitutes an OE pump: If an O'Reillys reman supplier uses an original Honda casting and places their own supplied internal parts in it, is it still a GENUINE Honda P/S pump ?
OP, can you elaborate more as to why you have asked this question ? What are your concerns ?
Old Feb 14, 2021 | 07:14 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Now that is a very good point.
Old Feb 14, 2021 | 01:06 PM
hawks85's Avatar
I have gone through 3 aftermarkets pumps this year, they keep failing and leaking, and I am sick and tired of it. Honda discontinued the pump for my 99 civic. Now my only options are a junk yard or the internet. I want the real one.
Old Feb 14, 2021 | 08:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I would try to find a clean, low mileage one at the junkyard. Remember the OE sticker on the edge.
Old Feb 16, 2021 | 04:46 PM
hawks85's Avatar
Thanks! Is it possible you can show me a pic of the OE pump with the sticker on the edge. I apologize, but I don't know what the edge is, and what does the OE sticker look like.
Old Feb 16, 2021 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Let me see what I can find for you.
Old Feb 19, 2021 | 05:37 PM
egsleepercivic's Avatar
Have you though about trying to rebuilding it yourself?, I believe its just a couple of o rings if the bearing is good
*edit here is the link for a 99 ex, shows the seals needed
https://www.hondaautomotiveparts.com...gine--p-s-pump
If you rebuild with Honda seals should be good, also make sure you are using PS fluid meant for Hondas specifically, doesn't have to be Honda brand, but should say for Honda and Acuras
Old Feb 19, 2021 | 07:26 PM
tony_2018's Avatar
Fish Twig
what fluid?
myrrh81
Jul 31, 2007 02:04 PM
QuickDxEk
Nov 25, 2006 09:56 AM
dodge
Jan 14, 2002 09:29 AM
apexii
Aug 7, 2001 01:07 PM
