Clutch problems d16y7manual
Old Feb 8, 2021 | 07:16 AM
Nino Brown's Avatar
Default Clutch problems d16y7manual
So my clutch pedal keeps going out..I have replaced slave cyl and master.and the clutch, pressure plate, also throw out bearing and pivot ball...wth am I missing. Clutch is good then is gone..someone help
Old Feb 8, 2021 | 08:37 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Clutch problems d16y7manual
Did you bench bleed the master cylinder? I suspect air in the lines which is impossible to be rid of if you don't bench bleed the master before install.
Also if you replaced with a used unit, it could be bad from the get go.
Old Feb 9, 2021 | 08:45 AM
Nino Brown's Avatar
so my mechanic did the install i asked and he said he did bleed it..so im still like idk im gonna try and replied system again and add high performance braided clutch line...any good ideas on how to bleed in situations like this???
Old Feb 9, 2021 | 05:15 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Is the master new or used?
Mike banX
Transmission & Drivetrain
Feb 16, 2011 06:58 PM
94_Teggy
May 11, 2009 10:58 AM
nsimov
Nov 28, 2005 08:04 PM
iwreakhavoc
Jun 3, 2005 10:47 AM
stRtypR25
Jan 21, 2003 08:45 PM
