2000 Honda Civic DX No Crank, No Fuel Pump Prime.
Old Feb 7, 2021 | 01:34 PM
Dom_LB's Avatar
Default 2000 Honda Civic DX No Crank, No Fuel Pump Prime.
Hey guys, I have a 2000 honda civic ex with the 1.6L engine. We replaced the engine in it recently and have more than verified the connections. I can't get it to start or even prime the fuel pump. I know the ignition works, as well as the starter and fuel pump. I've also replaced the main relay 2 times. The computer was replaced recently with the same results. Any help would be appreciated.
Old Feb 7, 2021 | 02:56 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 2000 Honda Civic DX No Crank, No Fuel Pump Prime.
Did you replace the engine with a JDM 1.6L engine or USDM version?
Old Feb 7, 2021 | 05:30 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Does the CEL light come on and off if you turn the key?
Check the ground points in the engine bay. Particularly the one on the thermostat housing and the main on the transmission.
Old Feb 7, 2021 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This.
Old Feb 8, 2021 | 09:35 AM
Dom_LB's Avatar
[QUOTEwunfstgsr;52357749]Did you replace the engine with a JDM 1.6L engine or USDM version?[/QUOTE]
Verified... Anything else that could cause that?
CEL does come on
Old Feb 8, 2021 | 12:43 PM
muellersfan's Avatar
CEL does come on
And stays on steady, right?
If so, start by checking whether you forgot to connect the important G101 ground that attaches to the thermostat housing, as mentioned by another member.
Ryan2000ex
14
Apr 20, 2020 12:29 PM
GiantDad
15
May 28, 2018 10:18 AM
jvaldovi
25
Sep 21, 2016 10:22 PM
allvtecyo
Dec 20, 2013 06:59 PM
civicdx92
Jun 25, 2006 05:09 PM
