2015 Accord Sport Cranks but doesn’t start
Ok guys. I hope someone has any ideas.
The problem started when my wife said the key lock & unlock wasn’t properly working. Right after, the car no longer wanted to start. When you press the lock and unlock, the red light lights up on the key, then stays lit for a few seconds (random) and then light turns off but the signal never sends instruction to the car to unlock or lock.
so ignorantly, I replaced the starter, crank and camshaft sensors.
the car only cranks but never turns on.
I seriously thinks it’s electrical, but then again, I am speaking ignorantly.
does anybody have any ideas???
Okay so it sounds like you aren't getting fuel so the best way to test this is get in the car and close the door. Secondly put on your seat belt and turn off radio and anything thats going to make any extra noise. Third DONT PRESS BRAKE you will then press the start button 1 or 2 times until you see all the lights on the dashboard lit. simultaneously listen for a buzzing sound coming from the back seat if you do not hear that sound get a second person JUST TO BE SURE to press the start button until the lights are lit and while they are doing that put your ear by the left back tire and listen for that buzzing sound (it only last for 3 seconds) make sure you act quickly or you'll have to do this again. THERE IS A RECALL ON THE FUEL PUMP SO DONT BUY ONE.
Secondly the remote is doing what its doing because the battery on the remote could very well be dead and thats its way of saying that and its a chance thats the reason it isn't starting because the immobilizer isn't either getting the signal because its weak from a dead battery or it isn't getting signal at all because if the dead battery its just a security feature so you should change the battery.
walton2007
Sep 13, 2010 03:58 AM
Richard.
Nov 17, 2003 08:39 AM
