Accord 2007 v4 sedan not starting
Hi, I am new to this forum so I apologize before hand if I need to post this elsewhere, as well I am not to knowledgeable about cars so I figured the best thing to do would be to post here.
Anyway... I have a 2007 V4 sedan with about 33K miles and its not starting. Everytime I try to turn the car on it makes almost like a buzzing noise which then slowly dies down. The gas range goes up and down, the lights turn on but are very dim. The car will not rev at all it just makes that very weird sound. As well, the lights in the dashboard turn on but sort of blink, they do not stay stable, earlier the radio turned on, but now it doesnt turn on either, and it almost sounded as if CDs were changing when I did not even touch it.
I had last used the car a week ago and it was up and running fine, I came home from school this weekend and it wont start, I have no idea what to do.
Any help is highly appreciated, thank you very much in advance!
Re: Accord 2007 v4 sedan not starting
Has anyone checked the charging system to be sure it's charging? I mean, I doubt the alternator has failed at 33,000 miles, but worth checking.
Just throwing out a guess, I'd say you have a bad battery - from your description.
Dead battery. A temp solution would be to get a jump and let it run for 30-45 minutes to recharge. If it's a bad battery though it may drain again.
fivestarpacheco
01-07-2019 05:17 PM
Marla
Honda Accord (2013 - 2015)
02-01-2018 09:24 AM
walton2007
Engine Management and Tuning
09-11-2010 10:01 PM
