What's easiest eg chassis for b18c1 swap??? ( First time swapper)
Old Feb 4, 2021 | 10:39 AM
Wrenchen1989's Avatar
Default What's easiest eg chassis for b18c1 swap??? ( First time swapper)
So I just ordered up a b18 C1 with GSR transmission and everything to go along to do the swap. I am just wondering what is the easiest eg chassis for this swap, as far as to wire everything up , I have the OBD1 GSR ECU and wiring harness with the swap. Any advice would be greatly appreciated thanks honda techs.
Old Feb 4, 2021 | 02:57 PM
tony_2018's Avatar
Fish Twig
Default Re: What's easiest eg chassis for b18c1 swap??? ( First time swapper)
huh???
Old Feb 4, 2021 | 06:53 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Did your swap come with the B18C wire harness?
The 1992 year Civics are the best since every trim level (CX/VX/DX/EX/SI) were wired for VTEC from the ECU to the engine bay shock tower. That would only require you wire in the following in a 1992:
  1. Knock Sensor
  2. IAB
  3. EVAP Purge
  4. Maybe O2 Sensors (there are some models that have single wire, 4 wire, and 5 wire sensors depending on models...you will need the 4 wire O2)
If you have a 93-up, then you will need to wire the following from the ECU to the engine bay:
  1. VTEC Solenoid (excluding EX/SI models since those had VTEC motors)
  2. VTEC OPS (excluding EX/SI models since those had VTEC motors)
  3. Knock Sensor
  4. IAB
  5. Evap Purge
  6. Maybe O2 Sensors (there are some models that have single wire, 4 wire, and 5 wire sensors depending on models...you will need a 4 wire O2)
If you need pinouts to your ECU:
92hatchattack
Oct 12, 2006 11:17 AM
kyorishin
Jun 13, 2006 09:11 PM
vtecnologist
Apr 20, 2006 03:31 PM
NatedoggAZ
11
Apr 15, 2004 11:30 AM
juicy.koreans.suck
Dec 25, 2001 01:54 PM
