Crankshaft bolt tool for 1999 prelude
Hey yall
I'm doing my timing belt but im stuck at the crankshaft bolt removal phase for my 1999 prelude. I got the honda 50mm crankshaft removal tool but I can't put it into the crankshaft because the frame is in the way. Is there another way to put it in? Did I get the wrong part? Do I have to lower the engine or something? I would have tried to put the car in 5th and tell someone to step on the brake but it's an auto. Btw can I even shove a prybar in the hole that's covered by the rubber thing and try to wedge the flywheel to stop the pulley from turning?
Thanks
Thanks
Thanks for the detailed post and suggestions. 👍I'm gonna try lowering taking off the driver side mount and lowering the engine while supporting it with a jack. And then using that crank pulley tool and a breaker bar and a extension or pipe.
I grabbed a timing belt, balance shaft seal, retainer, cam seals, main seal, water pump, ps and ac belts.
I didn't grab a manual tensioner though.
I'm in Canada so I'm just going to use amazon Canada. is this all I need for the manual tensioner conversion? Or do I need some other parts?
Just an update. I lowered the engine a little bit via loosening the engine mount bolts so I could fit the tool on the crankshaft pulley. That bolt was a *@#&. I had to jack the car higher and then remove wiper fluid reservoir to get more leverage. The used a pipe extension on a breaker bar and stepped on that and it came off. Also use a 6 point socket on the cam shaft bolts. I used a cheap wrench like a dumb *** and rounded some of the edges off.
marc antony
Oct 23, 2019 06:16 PM
