Map sensor
Old Jan 24, 2021 | 09:31 AM
Karl Graves's Avatar
Default Map sensor
What other vehicles map sensor are interchangeable with a 92 Honda Accord
Old Jan 24, 2021 | 12:14 PM
99stockcivic's Avatar
Default Re: Map sensor
Out of curiosity, why would you do that? You can get the correct one for $20. Are you searching in a junnkyard?
Denso TN079800-2550
https://www.ebay.com/itm/18252521284...gaAl_7EALw_wcB
Old Jan 25, 2021 | 12:55 PM
GhostAccord's Avatar
That is not the correct map sensor for a USDM F22A engine, the link posted seems to be for a European Accord 2.0i maybe.
If this is for a US made vehicle any 90-02 chassis with a 3 wire,2 bolt, throttle body mounted MAP sensor will work. all trims Civic, Accord, CR-V, Prelude, Odyssey or Integra.
Denso -TN079800-3280 and or TN079800-4250... I think any of them that start with TN079800-XXXX will work.
Old Jan 25, 2021 | 06:53 PM
I apologize, I didn't mean to post the wrong part numbers, thanks for catching that.
Old Jan 26, 2021 | 10:32 AM
Noah Lehman's Avatar
I have one I pulled from a 97' w 155k miles on it. I pulled the VSS as well and that fixed my odometer problem for the most part.
J Rad
Jan 8, 2021 08:42 AM
Prorican
Sep 24, 2006 12:39 PM
fubuallstar
Jan 10, 2005 05:20 AM
