92 Civic cx blinker/cluster problems
So this issue has been ongoing for a while now and I can't figure it out. My cluster, blinkers, clock, fuel gauge, and handbreak light (on the cluster) do not work. When I first bought the civy everything went out very occasionally so I didn't worry that much (bad decision). I assumed it was some loose wiring or something because I had to hit "under" the dash where the ECU is to make it turn back on. Now it has completely shut off, and hitting under the dash does not fix the issue. I looked under the dash, I don't see any loose wires or shredded harnesses. QUICK NOTE: My left rear taillight had water in it, and I had to replaced all my bulbs, I cleaned out the corrosion. I don't know if this is related to the issue) Anyways, I recently replaced my steering wheel (and the rear tailight bulbs) and unplugged/plugged some stuff back in. EVERYTHING STARTED WORKING for like 5 seconds untill I tried to use my blinkers again 😂. It immediately shut back off. It can't be a blown fuse, a bad cluster, bad switch, or something that's broken because it turned back on after a month of not working. I don't wanna go replacing things and waste money on a new cluster or something. Please help 🙏
