Questions regarding the minime swap
Old Jan 20, 2021 | 05:26 PM
gallardoh's Avatar
Default Questions regarding the minime swap
Hello everyone!
I am planning a minime build for my EG and I wanted to ask some questions.My plan so far is to take the d15 block and d16z6 head to make my minime build like so many before me. However I cannot wrap my head around two main things. My EG is a canadian model called CX (I live in Sweden), it is a 1.5 liter engine with a carborator. That engine is leaving the bay. Now, my plan is to go turbo and I plan on changing the connecting rods aswell as pistons to lower the compression. According to the d-series compression calculator
With d15 block and crank, z6 head, z6/y8 gasket and and estimated block decking and head milling of 1mm, I land at a compression ratio of 8.95:1.
Q1: Should I go even lower on the ratio? (8:95 sounds great to me?)
Q2: Does anyone know if I will have to get myself a new wiring harness with this wierd cx carborated d15 engine (My guess is yes?), or do I only need the d16 vtec ecu?
Old Jan 20, 2021 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Questions regarding the minime swap
1) Do NOT mill the head/block 1mm. This is a terrible idea and will cause cam timing and T/B tension issues. Leave the head and block surfaces original unless you absolutely have to mill them... and then, only the minimum required AND purchase a Cometic head gasket that is the same increase in thickness as the amount removed from the head/block.
2) Modern engine management has made lowering the compression on an engine a thing of the past. There is nothing wrong with running something between 9 and 10:1.
3) Yes, you will have to change out your engine harness because you will no longer be using a carb. You will be going to multi-port fuel injection.
mike93eh2
Feb 11, 2009 08:09 PM
sohctodohc
Sep 12, 2007 09:52 AM
MrCrowley.
Aug 5, 2006 03:51 PM
egturbo
15
May 7, 2004 03:53 PM
