Transmission & Drivetrain Gearboxes, Differentials, Clutches
9th gen trans rebuild
Old Jan 20, 2021 | 02:22 PM
Vinnysfb6's Avatar
Default 9th gen trans rebuild
Hello everyone,
I recently came across a good deal on a 9th gen trans casing with 8th gen internals and a wavetrac lsd for 800 cad. Ive been planning on re building my transmission for a while now since the car has turned pretty much into a track car with the occasional cruise around town. I was basically waiting for something to break before I decided to dish out money on a rebuild but this deal is too hard to pass on. My plan for a tranny build was to always go with DC5R gearing. From my research, the k20z3 1-3 is the same as the dc5r with the 4-6 dc5r gears being shorter. The plan is to also keep the k20z3 6th gear for highway cruising. Most of the tracks that I go to are hours out and mainly highway driving and I dont think sitting at 4000+rpm the whole way in a gutted car will be any fun. So my main question is if I wanted to upgrade to carbon synchros from synchrotech, would i have to get a seperate 4th and 5th dc5r synchro or are all K series synchros interchangeable? Dont really care for 6th gear but I wouldnt mind upgrading the rest while I have the trans open. My second question is, would it be better to upgrade to lets say a 5.06 FD from a FD2 type r or stick with the oem 4.7. The car just sees circuit tracks never any drag and I plan on just sticking with N/A. If anyone has any experience with a similar setup and tracks their car religiously then any advice will be appreciated.
Old Jan 22, 2021 | 06:18 AM
Aquafina's Avatar
Default Re: 9th gen trans rebuild
If you want to use the ITR 5th gear and the "stock" 6th gear, you'll have to order the synchros separately. ITR uses dual cones synchros 3-4-5-6. Si uses dual cone 3-4 and single cone 5-6.
The 5.0 FD will raise the cruising RPM by about 225 RPM.
The 4.7 FD with ITR 6th would raise the cruising RPM by about 350 RPM.
I prefer longer FD and closer gears for track use.
stallinrawlings
Mar 8, 2013 03:57 AM
Black R
Aug 22, 2008 04:54 PM
oneludesol
Jan 27, 2008 08:37 PM
VTECAcuraGSR
16
Jan 21, 2007 05:30 AM
Bense
Oct 18, 2006 08:06 PM
