Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 EX revised Timing belt Tensioner bolt part # ?
Old Jan 19, 2021 | 11:58 AM
egsleepercivic's Avatar
Default 2002 EX revised Timing belt Tensioner bolt part # ?
I am doing some work on a buddies 2002 ex, I am going to do the Timing belt and water pump with the following kit.
Amazon Amazon
I have been reading a lot that the tensioner bolt has been changed and is longer to avoid the issue below
http://www.napabeltshose.com/~/media...n-pa007-11.pdf
Is there a new part # from Honda for the bolt or is available at the local stores ? prefer the honda part # I see some of the aftermarket tensioners come with new bolts
14517-PLC-013 not sure if that is the new or old part # ?
https://www.hondaautomotiveparts.com...ft-timing-belt
If anyone can confirm the correct part # for the new bolt it would be appreciated, I don't ever work on the new stuff usually 95 and older
Old Jan 20, 2021 | 05:14 AM
NDNV's Avatar
Default Re: 2002 EX revised Timing belt Tensioner bolt part # ?
Your part # for the tensioner bolt matches this website (part #12): 2002 Honda Civic EX 4D CAMSHAFT TIMING BELT (sonshonda.com)
Another site had a part # history as:
Part Number History:
  1. 14517-PLC-013
  2. 14517-PMM-A01
  3. 14517-PLC-003
Looks like 14517-PLC-013 is the latest part #...
Old Jan 20, 2021 | 08:40 PM
  1. 14517-PLC-013
  2. 14517-PMM-A01
  3. 14517-PLC-003
Thank you !
ke7joi
Classic Hondas
Jul 16, 2014 07:51 AM
kenzo42
Mar 21, 2014 05:26 PM
chope045
11
Aug 15, 2011 11:16 PM
v8 integra
Apr 17, 2006 10:33 AM
91civicEX
Jul 24, 2003 06:33 PM
