Honda CR-V & Element 2WD & 4WD Element & CR-V
05 CRV charcoal canister and Evap.
Old Jan 10, 2021 | 09:37 PM
Utsikt's Avatar
Default 05 CRV charcoal canister and Evap.
Hello, I ended up smashing my canister so I decided to tear it out so it doesn't happen again and get mangled in with the CV. My question has to do with finding out what line does what. I have seen a few diagrams and just trying to figure out what lines should be left to vent and what should be plugged. After pulling out the box I'm left with 2 bigger Dia rubber hoses, one hardline that has positive pressure at idle and the other is a small Dia rubber line that connects to a sensor that it was plugged into a wore harness and then plugged into a nipple coming through the frame.
​​​​https://www.hondapartsnow.com/parts-list/2005-honda-cr_v--5dr_ex-ka_5mt/electrical_exhaust_heater_fuel/fuel_pipe.html
Off this diagram. I have the hardline connected to #21
#14 connected to #15
Rubber hose #25/#26 hanging down. The other big hose isn't shown on the diagram but would connect to a nipple on the canister beside where #21 would connect to canister.
I have a feeling that #21 and the rubber hose not on diagram are purge lines.#25/26 is a drain as mentioned on part diagram. #14 line connected to #15 is just a pressure sensor. If that is correct what line then would then head back to the intake on vacuum. That vacuum line would be the only one needed I think to cap/plug but I'm not sure where it is. Any help is really appreciated.
Maldito X
Jun 16, 2010 05:50 AM
90Rexx
Mar 11, 2009 05:59 PM
Kaspk
Apr 6, 2007 03:12 PM
B16b-EJ8
Oct 25, 2006 03:28 PM
xci_ed6
Aug 10, 2002 05:35 PM
