Obd0 to obd 1 swap
Old Jan 10, 2021 | 09:28 AM
nexsus5 mobile's Avatar
Default Obd0 to obd 1 swap
Hi, I change the ecu from obd0 to obd1, the car start, but I have one long and one short flash on the engine check light, any ideas guys?
Old Jan 10, 2021 | 10:27 PM
Deeps's Avatar
Default Re: Obd0 to obd 1 swap
On OBD1 ECUs, ecu codes are thrown via the flashing check engine light. A long flash is a 10 and a short flash is 1. So sounds like it's throwing a code 11. According to another thread, it has to do with an IMA sensor.
Originally Posted by sanimalp
There is a code 11.. it is for cars that were sold without a catalytic converter.. Code 11 is for a sensor called the IMA sensor.
The IMA sensor manages how much CO is in the exhaust using the O2 sensor as a guage.
Since you didn't mention what ECU you are running, its a guess, but my money is on that you have an ECU looking for an IMA sensor, and a car that doesn't have one.
Your options are to get a different ECU that does not expect an IMA sensor, or do the work to install the IMA sensor the ECU is looking for.
Old Jan 12, 2021 | 06:00 PM
Marcos Barrios's Avatar
to go obd1 from obd0 is not only changing out the ecu
you also need the distributer
and the 4 wire 02 sensor
the code your getting sounds like its because the 02 sensor is either not hooked up
or it isnt workin right
thats where i would start looking if it were me
good luck
Old Jan 15, 2021 | 02:13 AM
good luck
Yes, I change distributor and put 4 wire O2 sensor, I use speed factory harness, maybe I not find exactly wich cables going to o2 sensor
dougshatch
Jun 11, 2007 06:38 PM
Car2n134
May 8, 2007 10:39 PM
vtec fan
Feb 3, 2004 10:48 AM
gokooljapan
Mar 14, 2002 06:13 PM
