Hey guys. Had to make a new user ID because I lost my email for the old one(99civ - If someone can unlock it, let me know). However, I need the bolts that go into the subframe for a sway bar/bracket. I'm adding a 24mm and the bolts that came with aren't correct and the company is worthless to talk to. No search will bring me to a solution, as it always takes me to the LCA bolts which are readily available. If anyone has info on where to purchase, etc. Majestic Honda(diagram below) does not list them as produced by Honda anymore. Thanks!!
Hondapartsonline shows them as still available as it's still used on just about all new Honda cars/trucks. You should have ZERO issues buying these at any Honda/Acura dealer.
Thanks. I'll call a different dealer tomorrow and see if I can get a better result or just order off there. Thanks again.
QUOTE=Feriohhh;52335364]Hondapartsonline shows them as still available as it's still used on just about all new Honda cars/trucks. You should have ZERO issues buying these at any Honda/Acura dealer.
