How to check Lambda sensor
Good evening all,
I've read alot of topics and watch many videos how to check whether oxygen sensor is working or not, however my father honda civic has 5 wire sensor and i'm not confident how to proceed. Can you give me some advises please? Thanks.
Honda Civic LS circa 1995, D15Z3 VTEC-E
Good evening all,
Do you have any check engine codes/light ?
You can try buying a Haynes manual online or from a auto parts store and look for the trouble shooting steps for the O2 sensors, they should guide you on how to test them.
Thanks, a lot. Yes the engine light is on for some reason, not sure if it is the o2 sensor or something else.Have to explain my father the trick of reading the code number by the engine light as he is not having engine tester. Hope i can apply this method on this particular model(shorting the green connector pins). Will post you the results.
hipramodbhu
28
Feb 27, 2015 08:25 AM
WhiteXHysteria
May 1, 2012 01:23 AM
rotascircuit
Aug 6, 2007 10:30 AM
SiShane
Sep 4, 2004 04:48 AM
