ED Civic AWD conversion?
From: Cheney. A little town outside Spokane Washington.
Can you do the EF AWD Swap on an ED Civic of the same year so long as you also swap the tranny, knuckles/spindle and axles? The only difference I know of is that one is JDM and the other is Canadian.
I want to know because I have an ED Civic that I'm swapping in EF axles, transmission, knuckles, half-shaft, and a D16Y5 that I'm putting a built Y8 head on with a tuned P28 ECU. I hope to turbo it by putting in a spacer and increasing the combustion chamber through machining. That or do a vitara build which is simpler, and after I'm done driving it into the ground I want to know if I can convert it to AWD and run big power on the street or not. Like a K or B swapped AWD EF Civic can.
the short answer is yes you can do all of these things
because both cars are pretty much the same thing parts wise
now what im a little gray on is the spacer you want to use to increase the chamber space
do you mean a thicker head gasket?
like a 3 layer steel one for example?
Thank you for your response. I've been asking everywhere and you're the first to respond. It's important to me because I really want to convert this car to AWD some day since before stripping, tubbing it out and doing other weight reductions it already only weighs 1,800 lbs. Making it the perfect potential sleeper car. Meaning that with moderate power gains it can become very fast and no one would suspect a 30 year old hatch made in Canada. The AWD will also help a lot because it'll weight so little once it undergoes weight reductions that it'll be hard to stick the power to the ground. Making AWD necessary and the added drivetrain will put weight in the rear. Effectively balancing it out again for turning it.
This is also the first Honda and the oldest that I have collected. So there's a nostalgia factor.
your going to have alot fun with this
and ill be honest with you
what you wonna do to your engine sounds nice but its not nessesary
you replace the pistons with ones with beafy rods only
and then you add boost about 9-12 pounds and youll have something like this
this is an old friend of mine
this is danas red crx that he keeps breaking
because he has too much power , a good balance would be about 40 hp less than what he has
but dont tell him that ^_-
https://www.youtube.com/watch?v=qOjduVH9eJg
However, when I build it again to be AWD I will very likely use a B20b like your friend because they are cheap (about $700-$1300 used). Though I'd rather have a turbo K24 with a K20 head. they are much more to buy and much much more expensive to build.
Even though your friend is about 20-40hp over (imho as well) he really has his act together. I hope to be as knowledgeable as him when I go AWD.
http://www.civicwagon.com/discussion...n-and-keep-4wd
D16A6=YES
D16A1= NO
D16Z6=YES IF IT HAS THE MOUNTING FOR THE INTERMEDIATE SHAFT
SOHC ZC=YES
ZC/D16A8/9=YES
D16Y8=NOT SURE
D15's=NO
Mac-10™
Apr 8, 2013 10:45 PM
blkSi
26
Mar 8, 2012 03:38 AM
jawsiiv
Mar 20, 2008 07:33 PM
