1994 civic lx oil filter stuck
Old Dec 12, 2020 | 09:34 PM
Lecarz's Avatar
Default 1994 civic lx oil filter stuck
Recently purchased a 1994 civic lx went to do a oil change only to find the filter was stuck there isn’t enough room for my oil filter wrench to get a good grip and no room for the hammer and screw driver method anyone have and tips.
Old Dec 13, 2020 | 05:09 AM
muellersfan's Avatar
Default Re: 1994 civic lx oil filter stuck
Check whether one of these oil filter wrenches fits. If not, return.
https://www.harborfreight.com/oil-fi...RoC76IQAvD_BwE
Old Dec 13, 2020 | 10:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I personally hate those cap oil filter wrenches, I find them to be mostly useless.
My favorite is the two jaw utilizing a 3/8" ratchet driver. I've used it exclusively after working in the lube shops for a few years. It works even on dry gasket filters when all others fail. The screwdriver hammer trick is usually a bad idea as the canister gets tore up and then you are in an even worse predicament to get the filter off. Or should I say, the remains of the filter.
This one in particular for our smaller oil filters, they make a larger version for the bigger V8 filters etc:
Amazon Amazon
Old Dec 13, 2020 | 11:43 AM
The caps work great when they fit the filter. When they don't fit, they don't work.
I have the wrench at your amazon link. In my experience, it's weakness is a tendency to slip.
Old Dec 13, 2020 | 05:21 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I found the weakness you mention be for the cap version while the clamp just bites in more and more the more pressure you have to use to get the filter off.
Interesting indeed. I like it because it doesn't slip, but you found it slips for you. Definitely not the same experiences.
Old Dec 13, 2020 | 05:22 PM
Very true.
Old Dec 15, 2020 | 02:39 PM
NVturbo's Avatar
O.G. triple O.G.
I use this and it removes ANY OIL FILTER. Just don't use it during install.
Old Dec 17, 2020 | 01:32 PM
99stockcivic's Avatar
I find this amusing, as this is common experience for many of us. I literally have all of the above wrenches, as each time one would work better in some situations (or even some types of filters), than others.
Old Dec 18, 2020 | 08:19 AM
spAdam's Avatar
Loved
Community Favorite
If you're in a pinch with the car off the ground, oil drained out, and none of the above tools, a leather belt makes a great strap wrench. I've yanked mine off and used it without even climbing out from under the car.
Then go publicly chastise the person who put the too-tight filter on. Never use a tool to install.
Old Dec 18, 2020 | 11:45 AM
Daren73's Avatar
The Lisle 63600 works great. Can get it on Amazon or EBay.
Old Dec 18, 2020 | 01:12 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you don't put a little oil on the rubber gasket, the filter is a real pita to remove.
Sometimes it wasn't because it was put on too tight instead, a novice didn't know to rub a little oil on the o-ring of the filter.
I absolutely HATE dry gasket filters from novices... OMG I can't express enough exasperation for those!
