Where to buy geniue OEM b16b timing belt/water pump
Old Dec 8, 2020 | 12:51 PM
GummyHonda's Avatar
Post Where to buy geniue OEM b16b timing belt/water pump
Hello,
In the near future im going to replace the timing belt and water pump on my b16b. Where online can i buy an oem belt/wp? Ive called my local honda dealer and they said they cant get one.
Thanks.
Old Dec 8, 2020 | 03:54 PM
Ryanthegreat1's Avatar
Default Re: Where to buy geniue OEM b16b timing belt/water pump
They can't get timing parts for a 2000 Civic Si? Should be the same bits.
Old Dec 8, 2020 | 04:15 PM
GummyHonda's Avatar
No, the b16b engine is a JDM import from the ek9 Type R. It was a longshot as the engine/car was never sold in the USA but regardless i dont know where to buy a timing belt/wp for the engine
Old Dec 8, 2020 | 05:01 PM
Lasty K's Avatar
Even though it wasn't sold in the US, the B series still shares many components as their other B series counterparts.
B16B runs timing belt part #14400-P72-014, and water pump part #19200-P72-013. Both of which you could still currently buy off any Acura parts website.
So essentially they share the same VTEC water pump from a B16A2 (99-00 Civic Si), but uses the timing belt from a B18C5 (97-01 Integra Type-R).
Old Dec 8, 2020 | 05:20 PM
GummyHonda's Avatar
oh ok thank you for the help, my mistake
Old Dec 8, 2020 | 05:26 PM
GummyHonda's Avatar
Sorry for the reply to the reply,
I thought the engine code b18c1 is for an integra GSR not an ITR?
Old Dec 8, 2020 | 05:29 PM
Lasty K's Avatar
My mistake, yea B18C1 = GSR, C5 = Type-R.
Old Dec 8, 2020 | 06:36 PM
How do they make the longer B18 belt work on the shorter decked B16?
Old Dec 8, 2020 | 08:20 PM
Lasty K's Avatar
B16B block shares the same as a GSR/Type-R, and not the B16A2, so naturally it's taller.
Old Dec 8, 2020 | 09:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The B16B is essentially a "De-stroked" B18C5 ITR engine. The block casting is the same as the B18C1/5 block.
OP, in the US, with the exception of the B16B crankshaft, connecting rods, pistons and intake camshaft... you have a 2001 ITR (B18C5) engine. Check needed parts from an Acura Online Parts Seller... and then check the specific part number found through a Honda Online Parts Seller... and if it crosses over, you can buy the needed parts from your local Honda Parts Department. Otherwise, you get what you need from Acura.
