Car won't start - What could it be?
Old Nov 16, 2002 | 10:43 AM
vtec.dc2's Avatar
Default Car won't start - What could it be?
after alsmost 2 years, the car decided to take a dump..
Open the door, turn the key, all the lights come on in the dash like normal, then try to crank, the car makes a little scratching sound, - like .2 second sound and nothing after that.
Any suggestions?
Thanks
Old Nov 16, 2002 | 10:46 AM
2000 Integra R #760's Avatar
Default Re: Car won't start - What could it be? (vtec.dc2)
Battery?
Old Nov 16, 2002 | 10:50 AM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (2000 Integra R #760)
i'm still able to use the keyless entry, like everything else comes on, could it be something else?
Old Nov 16, 2002 | 10:52 AM
TypeR 599's Avatar
i bet it is the battery. all those little dash lights dont use much energy to work. try jumping it.
Old Nov 16, 2002 | 06:39 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (TypeR 599)
just got back.. it wouldn't make that noise anymore, just nothing at all.. so i tried to push/start it and it started rightaway.. its warming up as i'm writing this... hope its not the starter.
Old Nov 16, 2002 | 06:45 PM
itr1244's Avatar
starter maybe dead?
Old Nov 16, 2002 | 06:46 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (itr1244)
starter maybe dead?
so its possible to start the car without the starter?
Old Nov 16, 2002 | 06:56 PM
vtec.dc2's Avatar
o.k. i let the car wam run for 10-15 minutes, turned it off
turned the key, waited for fuel pump to stop making noise, then tried to crank it and nothing - no noise at all. will try to replace the battery tommorow..
btw.. is it possible to start the car without starter?
Reid's Avatar
Global Moderator
No
Old Nov 16, 2002 | 06:58 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (Reid)
hmm.. thats kinda good news... then it must be the battery.. will found out tommorow
MiraiZ's Avatar
push start...with ignition in on position, push the car a bit ( in neutral), while rollling, put it in gear, then pop the clutch.
Old Nov 16, 2002 | 07:00 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (MiraiZ)
thanks, already done that, (i mentioned that in last replies)
Old Nov 16, 2002 | 07:04 PM
Chris's Avatar
Loose cable. Or dead battery.
Old Nov 16, 2002 | 07:07 PM
Reid's Avatar
Global Moderator
Default Re: Car won't start - What could it be? (Chris)
Good point, make sure all grounds are connected properly.
Old Nov 16, 2002 | 07:10 PM
vtec.dc2's Avatar
thanks, will check all that..
Old Nov 16, 2002 | 08:31 PM
Evil_Wizard's Avatar
I think someone stole my SIG.
Old Nov 16, 2002 | 10:22 PM
Bbasso's Avatar
No
Reid are you slipping, what about push starting? ( push -toss in gear- pop clutch-go)
Old Nov 16, 2002 | 10:24 PM
Reid's Avatar
Global Moderator
Default Re: Car won't start - What could it be? (Bbasso)
He obviously knew about push starting since he mentioned he already used that method to start the car.
Old Nov 16, 2002 | 10:25 PM
Bbasso's Avatar
Oh my bad, time for the bed then...
Old Nov 16, 2002 | 10:43 PM
DC5power's Avatar
battery or starter. I just replaced my starter last week. It's not that bad just $$$$.
Old Nov 16, 2002 | 11:35 PM
tjtruong's Avatar
New User
Battery?
I have the same problem, after 2 years I just tried to start it up one day and no go. I'm pretty sure its your battery.
tj
Old Nov 17, 2002 | 01:53 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (tjtruong)
update: jumped the car and turned out it was the battery, so got it replaced.
also, got rid of my other problem https://honda-tech.com/zerothread?id=269584
Old Nov 17, 2002 | 01:55 PM
B2FiNiTY's Avatar
Can you explain how this works?
Old Nov 17, 2002 | 01:58 PM
vtec.dc2's Avatar
Default Re: Car won't start - What could it be? (B2FiNiTY)
i think he meant place the key in on position, and as you rolling down the hill or somone pushes try to let the clutch in/out to start the car - as soon as you hear it turning push clutch pedal back in so it don't turn of - all should be done within second... you could do it both in 1st/reverse.
[Modified by vtec.dc2, 5:58 PM 11/17/2002]
Old Nov 17, 2002 | 01:59 PM
B2FiNiTY's Avatar
So... basically you roll the car, clutch in/out repeatly and the car will start on it's own?
