Air Tool advice??
Old Nov 16, 2002 | 10:37 AM
xjohnx's Avatar
Default Air Tool advice??
I've been tooling with the idea of picking up some air tools lately just for simple installs around the house (suspnesion, changing wheels/tires, exhaust, just little things). I found this one at sears, comes with an impact wrench, air ratchet, hose, etc, for like $330, is it a good deal?
http://www.sears.com/sr/product/deta...=null&bidsite=
Old Nov 16, 2002 | 10:39 AM
paul98itr's Avatar
Default Re: Air Tool advice?? (xjohnx)
It's what I got, and it works awesome. Used it on my exhaust install w/o a problem
Old Nov 16, 2002 | 10:41 AM
sackdz's Avatar
Doesn't look like a bad deal at all... be sure to pickup a tire filling nozzle w/ psi gague and a "sprayer" nozzle too! And impact sockets...
Old Nov 16, 2002 | 10:45 AM
xjohnx's Avatar
Default Re: Air Tool advice?? (sackdz)
I figure i could make my money back without too much trouble charging ricers 100 bucks to install suspensions and such.. I think i'm gonna go ahead and do it. how much should the impact sockets run? will i need seperate sockets for the ratchet too? or should they be interchangable?
Old Nov 16, 2002 | 10:48 AM
xjohnx's Avatar
oh, one more question, with the impact wrench and the ratchet, i should be able to adjust how hard it turns so i can tighten things down without over tightening them right, then just torque by hand?
Old Nov 16, 2002 | 12:21 PM
xjohnx's Avatar
Default Re: Air Tool advice?? (paul98itr)
Are the ratchets and such adjustable as to how much torque they put out (not looking for ft/lbs so much, but just as long as they have a soft mode, as well as a hard mode)? how hard is it to exhaust the full tank of air requiring it to turn the compressor back on?
Old Nov 16, 2002 | 12:23 PM
Rob :190:'s Avatar
one thing though, if you charge $$$$ to do suspension work, you *might* put yourself in a position to be liable to damages/injuries/etc.
rob- who used to lift jeeps/4x4 for pizza and beer.
Old Nov 16, 2002 | 12:24 PM
xjohnx's Avatar
Default Re: Air Tool advice?? (Rob :190:)
Heh, guess i'll make out some kind of liability waiver thing, although i doubt it'd hold up
Old Nov 16, 2002 | 12:39 PM
ZygSpeed's Avatar
hehe ... just do what the factory does, and say : FOR RACING USE ONLY!
Old Nov 16, 2002 | 12:50 PM
paul98itr's Avatar
Default Re: Air Tool advice?? (Zygspeed)
Yeah they are adjustable for speed wise, but torque will have to be by hand of course!
Old Nov 16, 2002 | 01:05 PM
non-VTEC's Avatar
looks good.......but those oil-less direct drive air compressors are so freaking loud you will have a headache after hearing it come on and off a couple times....
try to find one that is belt driven........thats what i have and it's not nearly as loud as my freinds direct drive compressor.......
Old Nov 16, 2002 | 01:12 PM
Mullet_SyTy's Avatar
Default Re: Air Tool advice?? (non-VTEC)
The compressor is good if you arent using it too much. Its slow to refill. Something like a cut-off tool will drain it fast. Also buy Ingersol Rand air tools as opposed to Crapsman. I used to work for Sears Autocenter, we got craftsman for half price and most of us still bought elsewhere.
Old Nov 16, 2002 | 01:46 PM
rainmanEK's Avatar
big strong guy
Default Re: Air Tool advice?? (98_ITR#396)
Ingersol Rand
Craftsman is fine for a hobby tool set!
eric
Old Nov 16, 2002 | 02:03 PM
sackdz's Avatar
Default Re: Air Tool advice?? (rainmanEK)
Yea they are kinda loud, but who cares?
xjohnx-I'm sure the impact driver has torque settings, just put it on low for tightening so you can torque by hand, and high for removing those pita fasteners.
Impact sockets are a good idea for breaking really tough stufff loose... I've broken a couple normal sockets with my cheapo gun... especially the deep set sockets... I think you can get a metric set for maybe $30.
Old Nov 16, 2002 | 07:43 PM
JDM nerbie's Avatar
New User
Ingersol Rand
IR makes the best air tools
Old Nov 16, 2002 | 07:47 PM
SilverS's Avatar
my neighbor has a oil-less one he uses it at 1am
Old Nov 16, 2002 | 08:07 PM
Art Vandeleigh's Avatar
Default Re: Air Tool advice?? (SilverS)
that sounds liek a really good deal. do you think that will break off the crank bolt? how much tq is that puttinf out. i have been debating to get on as well.....
Old Nov 16, 2002 | 08:32 PM
mugen76's Avatar
Default Re: Air Tool advice?? (Art Vandeleigh)
that coiled up yellow hose is cheap and useless. trust me. that's the first thing you'll replace after some usage. get a heavy duty extra long hose.. i got one from sears that rolls up in it's own storage reel. it really helps when you want to pull it all the way out to the driveway/alley to fill up tires.. or other odd jobs outside of the garage.
[Modified by mugen76, 9:33 PM 11/16/2002]
hoffmanp
Aug 13, 2014 08:59 PM
PatrickGSR94
Jun 14, 2007 05:50 PM
96Civic_Coupe
Mar 21, 2006 12:37 PM
dfoxengr
Sep 25, 2005 10:07 AM
