2013 CR-V whistle or scream? SOS!
So out of no where now there is a Whistle or a scream coming from the engine compartment it’s not a belt scream
softer then that
I put new transmission fluid in her
checked everything here is a video
what is it please help
Happy Turkey day!
softer then that
Happy Turkey day!
Green plug on the top side of the alternator opposite end of the belt.
If it is at full field the charging system thinks there is a large charging demand on the system. Could be a bad battery or something else.
Do you have a multimeter? Can you measure battery voltage running and not running? You might have a charging system problem if you killed a battery in 3 months and the alternator is whining.
