Civic 2000 AC Not turning on ECM issue?
Old Nov 22, 2020 | 11:11 AM
alextech's Avatar
5 Year Member
Default Civic 2000 AC Not turning on ECM issue?
So I bought this used car from somebody and the guy who had it put ground directly to the relay pin that is supposed to be grounded by the ECM. Luckily I have gotten experience with this kind of issue before on a infiniti g20 2002 car and it was the ECM. But on this car I am confused, the part that I did not understand is why the AC Clutch pin is reading 14v and is not reading 14v on the connector to the AC? I checked for continuity and it is ok. Also ECM PIN 17 continuity ok. I have never been so confused before, the ECM is not grounding the relay, it reads OL in ohms mode when AC is on. I did check volts on the AC pressure switch and I get 4.7v on the BLUE/WHITE wire and it does have freon. I will post back later if I find anything.
Old Nov 22, 2020 | 11:19 AM
muellersfan's Avatar
Default Re: Civic 2000 AC Not turning on ECM issue?
Does the clutch relay get battery voltage on pin 4? If not, check dash fuse 17. If so, the relay may be bad.
Old Nov 22, 2020 | 11:26 AM
alextech's Avatar
5 Year Member
Ok I did check fuse 17 and fuse is ok. About PIN 4, not sure which one is PIN 4, which is why I drew it. But now I can kind of see where 14v might be coming from, not sure if is the diode. Also I did change relay and it wasnt the issue. If the ECM is not sending ground, more than likely I think it could be my issue, unless I am missing something.
Old Nov 22, 2020 | 02:28 PM
Unplug ECU connector A. Turn key to ON(II) with A/C button OFF. Do you measure battery voltage at ECU pin A17 in the unplugged ECU connector?
Have you used a multimeter to test whether the A/C pressure switch is closed?
When you turn key to ON(II) and turn the A/C and blower on, does the condenser fan run?
Old Nov 22, 2020 | 02:35 PM
alextech's Avatar
5 Year Member
Pin A15 on Honda Civic 2000 says that it is an empty slot. Are you sure I am supposed to check this one?
Old Nov 22, 2020 | 02:48 PM
My apology for the typo. I should have typed pin A17.
Old Nov 26, 2020 | 10:04 AM
alextech's Avatar
5 Year Member
I figured it out, the ECM was bad. Exactly to what happened to an infiniti g20. Here is the video:
Old Nov 26, 2020 | 10:37 AM
Nice work!
Can you post pictures showing the exact location of the bad component and a link to the replacement part?
Any idea what caused the component damage?
Old Nov 26, 2020 | 11:26 AM
alextech's Avatar
5 Year Member
Right now all I have is the video. The part number is STA415A and I replaced it with NEC UPA1560H. It just has to be an N-Type mosfet. I ordered the part through ebay. Not sure what caused the issue.
Old Nov 26, 2020 | 12:23 PM
alextech's Avatar
5 Year Member
Ok I have an update. I did put the ECU back and it did turn on, but now it does not want to turn off. So I tried the other ECU that I bought and for some reason that one did not want to turn on. So then I started checking voltages with the car running PIN 17 had 14v and when I checked PIN 27 (ACP) the clutched turned on by touching it with my test lead and it has 4.7v, I am not sure how much is supposed to be. So I am suspecting I have an issue with AC Pressure Switch or AC Pressure switch cable.
Old Nov 26, 2020 | 01:17 PM
alextech's Avatar
5 Year Member
I checked continuity Blue/White wire from pressure switch connector to PIN 3 on condenser fan relay and it has no continuity, could this be my problem?
Old Nov 26, 2020 | 09:16 PM
^When either ECU is installed.
Old Nov 26, 2020 | 09:22 PM
This test result indicates that the Blu/Wht wire has an open. Also test the wire for a short to ground.
The test does not check continuity across the pressure switch.
Voltage at pin 27 should be ~5V, so your reading is fine.
Old Nov 27, 2020 | 08:05 AM
alextech's Avatar
5 Year Member
Ok, so I found the open wire on the Blue/White wire from AC Pressure switch.
I fix the open wire and it now works like normal.
Old Nov 29, 2020 | 09:10 PM
wunfstgsr's Avatar
Loved
Community Favorite
Great work!
Old Nov 30, 2020 | 05:36 AM
tony_2018's Avatar
Fish Twig
Wild goose chase. But this is a given when it comes to electrical problems.
