f22b1 head sensor wire snapped
typical bullet terminals you can find anywhere will fit this temp sender. good practice to cut away any wire that has hard, brittle insulation and replace with new. also replace that leaking distributor o-ring (the most likely cause of the wire breaking) and the oil-swollen heater hose. that's a ticking time bomb.
