My JDM 96 Spec covid Lockdown build
Old Nov 3, 2020 | 02:38 AM
Jed_Dc2's Avatar
Default My JDM 96 Spec Covid Lockdown Turbo Build
Decided to do a build thread as I thought some people might find it interesting.
Most of the the the work was covered this year during the first uk lockdown but to begin ill start in april 2019.
I came into the position where I was able to get an second "fun" car never had my heart set on a dc2 but always had a soft spot for them and still missed my old eg6 SIR.
Put a wanted add on facebook and was offered a this championship white teg about half an hour from my house.
Had a few mods like mugen twin loop back box, Hardrace engine mounts and 98 spec front brakes.
Also included in the sale was a set of Tein coilovers, I found the standard suspension to be very good just sat far too high for my liking.
It wasnt perfect and needed some love but didnt think id ever get the chance to buy one again so took the plunge.
These are the pics I was was sent and the first day I got it.
This is how it looks today after having a complete suspension and brakes rebuild with mostly new uprated parts.
Also Running a Link G4X ecu and will be rebuilding the engine for boost over the coming months.
Will add more later.
Thanks
Jed
Old Nov 3, 2020 | 09:47 AM
dc2iggy's Avatar
10 Year Member
Default Re: My JDM 96 Spec covid Lockdown build
That a good amount of rust in the front. How are your wheel arches?
Old Nov 3, 2020 | 10:07 AM
Jed_Dc2's Avatar
​​​​​​It's mostly just surface rust at the front.
front, actually looks loads better now it's had a clean.
Worst bit was the rear sills but it's been fixed now, all the arches were still good after I went over them with a wire wheel
Old Nov 4, 2020 | 02:03 AM
Jed_Dc2's Avatar
Default Re: My JDM 96 Spec ITR Covid Lockdown Turbo Build
First few months didnt go great.
The exhaust was blowing and whilst doing an oil change noticed the ebay manifold had cracked almost all the way round this was fixed but no flexi meant it happened again.
Decided to put a standard 96 spec manifold on it as the ebay one collector wasnt even 2.5" and the rest of the exhaust was a mess so that was fixed with a flexi added and the end result was pretty good. Really quiet out of vtec and not overly loud even at 8k. The induction noise is louder than the exhaust!
Once the coilovers and my number plate were on it looked pretty good.
Then after all that the clutch decided it had had enough, I manged to grind into 2nd at the side of the motorway and crawl home, I knew I was going to add a turbo at this point so got a stage 4 competition clutch and TTV lightweight flywheel
Next post is where things got worse and I decided it needed a full underside restoration/rebuild before it got any boost!
Thanks
Jed
Old Nov 5, 2020 | 02:55 AM
Jed_Dc2's Avatar
After the clutch went clutch went I got the side skirts off and stripped the rear interior.
Rear of the sills looked a bit worse for wear be was surprisingly clean up front and was some surface rust behind the plastics.
Once it was on the ramp to do the clutch and I had a poke about it was obvious the rear sills needed welding and the whole underside of the car really had to be done to make it acceptable.
New clutch didnt fix the the gearbox not going into gear either so I knew something was broken inside the box.
So soon as the garage became available it was up in the air and work started.
Dont have pictures of the other side on my laptop but it was much the same. After it was welded up we got it on axel stands and set about stripping the rear of the car to work our way forward.
Was never aiming for a show car finish just wanted it to be clean and easy to work on.
I used a combination of Dinitrol products for the underside, it was the 3 stage process with rust converter, cavity wax then underbody coating.
Both rear arms were stripped to component form ready for new wheel bearings, bushes and to be painted satin black.
By this point I had already bought Hardrace rear camber and toe arms, Powerflex black series bushes and Meister R clubrace coilovers.
Thats enough for this post will add more tomorrow
Old Nov 6, 2020 | 08:39 AM
Jed_Dc2's Avatar
Looked pretty good when it was all back together.
I decided to fit bigger rear brakes at the same time ended up using ep3 calipers and mb6 discs.
Now it was time to start on the front of the car.
Every single part that could be replaced was replaced with new or uprated parts
Old Dec 28, 2020 | 09:51 AM
L4urenZ's Avatar
Looks like a good purpose for spending your time in lockdown. Good luck and i will patiently be awaiting your built.
Old Dec 30, 2020 | 12:42 PM
wunfstgsr's Avatar
Loved
Community Favorite
Sweet!!
Old Feb 27, 2021 | 01:15 PM
H-PIMP's Avatar
Very nice work!
Old Mar 24, 2021 | 07:38 PM
MaXpeedingRods's Avatar
Really a good way to kill time in lockdown. Looking forward to more updates.
Old Mar 25, 2021 | 12:42 PM
ShinsenTuner's Avatar
No Jodas
Nice. What are MB6 discs?
Old Mar 30, 2021 | 08:39 AM
2fast2focus's Avatar
great work so far
biggie2005
Appearance Build Threads
21
Sep 16, 2021 08:04 PM
Jeffaj20
Jun 1, 2015 12:01 AM
Mr Ry
16
Apr 30, 2012 10:50 AM
adonai
May 1, 2009 02:45 PM
Odiedogcx
Honda Motorcycles
16
Oct 30, 2005 11:30 AM
