Hey guys, looking to buy a civic and I spotted this detail on the door. How does this happen? And will I need to replace the entire door or just the door panel? Here’s a picture
Hmm got yah, don’t know if I’ll be able to remove the panel since I haven’t bought the car yet, planning to go check it out soon. Can’t be that serious right?
If the window isnt shattered and still goes up and down without any nasty noises it most likely isnt that dented up underneath.
After thinking on it for a second the rods for the door handle are prolly the most likely thing to be damaged.
makes sense, owner did mention both windows had trouble going down but the other door panel isn’t damaged. I haven’t checked it out yet but hopefully it’s just the window regulators.
the plastic used on the panels of all 96-00 becomes brittle with age. I repaired mine with fiberglass after getting tired of using epoxy to glue back together. But i regret even using glues as this is thermo plastic and plastic welding would've been easier. As for recovering because the vinyls going to crease or rip it’s actually pretty easy to find near identical glue down with 3m 90/70 and heatgun to shrink corners/ glue down. Before recovering sand and smooth plastic/fiberglass/glued/welded seams.
Oh and if fiberglassing to patch it wont bond to plastic so take old cotton blend shirt and glue it to the good parts and then you can apply resin to patch.
