1991 EF Dome Light Issue
Old Oct 27, 2020 | 07:50 AM
Blknblue's Avatar
Default 1991 EF Dome Light Issue
Hey all
My dome light isn’t working and need some input to trouble shoot. I've changed the bulb and the fuse is not blown and all other lights in the car are working. Dome light stays off no matter which door is opened (EF HATCH).
Any thoughts on what this could be? Also stereo is installed and working fine. Thx.
Old Oct 27, 2020 | 09:41 AM
Tyson's Avatar
Default Re: 1991 EF Dome Light Issue
theres 1 power source and 3 ground points for the light. are you saying you checked for 12V power? the harness comes up the driver side B pillar. the 3 ground points are 1 right next to the dome light when switched to constant on, and 2 at the door jambs where the door switch directly grounds the power, completing the circuit on either side to turn it on.
check for 12V power.
Old Oct 27, 2020 | 10:01 AM
Blknblue's Avatar
No haven’t checked 12V power yet but will do that now. Thanks for this info. Very helpful!
Old Feb 10, 2022 | 04:13 PM
CanOfRockstar's Avatar
5 Year Member
How did this issue get resolved? I'm having the same thing in my CRX
Old Mar 9, 2022 | 09:50 AM
GR8DANE's Avatar
Check for power as previously mentioned and check that the ground points and bulb contact points are good and clean. If you have a multimeter make sure there is continuity between the parts that make ground to turn the light on (the dome light slider switch and the L shaped door pins) and battery or chassis ground. More often then not these contact point just need to be cleaned and/or scuffed up with some sand paper.
sajin
Feb 4, 2014 09:55 AM
eazy64
13
Nov 3, 2010 06:05 PM
Aftermath_Hatch
Dec 2, 2009 01:59 PM
JDM_SOHC
Mar 2, 2008 12:54 PM
streetuner
Jun 26, 2006 06:48 PM
